Repetitive Peak Reverse Voltage (VRRM) The repetitive peak reverse voltage is the maximum instantaneous value of the reverse voltage, including all repetitive transient voltages, but excluding all non- repetitive transient voltages which occur across the device.
Crest (Peak) Working Reverse Voltage (VRWM) The working peak reverse voltage is the maximum instantaneous value of the reverse voltage, excluding all repetitive and non-repetitive transient voltages which occur across the device.
The DC-blocking voltage is the reverse-biased voltage that if exceeded may destroy the diode.
