Loading [MathJax]/extensions/Safe.js
Author Topic: Will this work for switching 110V mini christmas lights on and off safely?  (Read 3547 times)
Offline jarrodhrobersonTopic starter
I have not been able to find any definitive independent documentation that the relay on this board will not burn my house down.
http://www.ebay.com/itm/New-1Channel-5V-Relay-Expansion-Board-Module-High-Level-Triger-for-Arduino-MSYG-/171666166850
It uses a SRD-5VDC-SL-C SONGLE which I can only really find any specs on in Chinese.
It claims Rated load: 10A 250VAC/28VDC,10A 125VAC/28VDC,10A 125VAC/28VDC
My plan is to replace all the timers that my wife puts on the lights on the wreaths that she hangs on the windows every year with a ATtiny/433mhz powered wireless receiver and one of these relays.
Will this actual switch US 110VAC safely? I know the lights are no where near 10A.
Then I can have one 433mhz transmitter trigger all the lights to go on and off at the same time instead of having to synchronize all these timers on each outlet.
« Last Edit: February 09, 2015, 12:00:43 am by jarrodhroberson »
Offline Paul Moir
Re: Will this work for switching 110V mini christmas lights on and off safely?
« Reply #1 on: February 08, 2015, 03:58:33 am »
The c RU us symbol on the top is a combination CSA & UL recognition mark, so that's a real good sign.  What they did on the PCB is a big question though.
However, I would say where minilights are concerned, if you put a fuse on the whole thing set nice and low you would be *way* out ahead in the not-burning-your-house-down factor.  I mean we get all concerned about clearances and ratings here, but what's really likely with them is to get a good arc going in the wires themselves from damaged insulation.
« Reply #2 on: February 08, 2015, 04:24:42 am »
Thanks for the reply, all the light strands have fuses build into the 110 plug on them now, so that should take care of that.
Offline Richard Crowley
  • KJ7YLK
« Reply #3 on: February 08, 2015, 04:43:41 am »
They are so cheap it would be worth buying a 5-pack just on speculation.  I agree with Mr. Moir that it somewhat depends on how well they designed the PC board unerneath. But I would have high expectations that it would safely handle modest loads like mini-Christmas light strings.
« Reply #4 on: February 08, 2015, 04:52:06 am »
This one has a nice slot designed into it so I think I will get it and try it.
« Last Edit: February 08, 2015, 05:35:01 am by jarrodhroberson »
Offline eneuro
« Reply #5 on: February 09, 2015, 01:01:15 pm »
Does it has some kind of softstart feature or this switch is too slow?
Anyway  too  many China characters on this board  :-DD
« Last Edit: February 09, 2015, 09:16:43 pm by eneuro »
12oV4dWZCAia7vXBzQzBF9wAt1U3JWZkpk
“Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine”  - Nikola Tesla
  • KJ7YLK
« Reply #6 on: February 09, 2015, 01:27:21 pm »
Yes, that example looks reasonably good.
My major complaint would be that it has no provision for mechanical mounting (like a couple of screw holes, etc.)
Do they think people will just let these things flop around in the breeze, "secured" only by the connected wires?
Offline Ian.M
« Reply #7 on: February 09, 2015, 01:53:45 pm »
Its also mechanically weak as the notched out area is approx 1/3 the width of the board.
Q. Would I use it for switching an amp or two at 12 or 24 V?
A. Probably if I had it handy + some foam VHB tape to mount it.
Q. Would I use it for >3A or >50V?
A. H**l No.  There is absolutely no way to mount it safely short of a custom moulded plastic mounting base.
Offline eneuro
« Reply #8 on: February 09, 2015, 09:36:34 pm »
Sometimes it is difficult to buy cheap PCB with good connectors, so I have my own footprint for such much more powerfull connectors 3mm inner diameter and 7mm outer ring secured with spring washer and submerged in non-conductive substance - hot glued ;)
Those connectors looks like those 24VAC transformer inputs below-not submerged yet, ready for testing after soldering this simple prototype +/-12VDC PSU for AC mosfets switch:
Of course it require a little effort to make proper wires, but it is better sometimes have something with label "Made  at Home" "NOT IN CHINA"  |O
« Last Edit: February 09, 2015, 09:38:28 pm by eneuro »
