Hi everyone.
I have an issue I need to solve.
I need to design a wireless button for activating a pump inside a machine. I need to make this wireless, and the transmitter should use as little power as necessary. This button will be pushed about 500 times a day. (its a liquid dosing machine).
A single touch on the button starts a dose. pressing it again quickly stops the dosing. You should be able to dose as long as you have the button pressed for a long enough time until release.
Transmitter should be powered by a 9v or so battery and it need to last a many moths as possible, and will be enclosed in a IPXX enclosure. Only the battery will be allowed to be changed.
Receiver will be inside the machine.
Does anyone manage how to face such an objective? any preliminary ideas?
Why does it need to be wireless? Unless the task
absolutely cannot be accomplished with a wired button, you should use a wired one.
Some things to consider:
- industrial environments are often full of interference
- a battery can fail at an inopportune moment
- wireless could be susceptible to malicious attack
- since you intend to use a toggling function (press and release to start, press and release again to stop), what happens if something goes wrong between the “start” and “stop” presses, causing the “stop” command to be delayed or lost? How much will the overfilled part cost to fix or replace? Does this create hazards to people or equipment?
- who is responsible for battery changes?
- what if the wireless button gets lost or stolen?
Also, an industrial push button switch that can handle 500 presses a day (that’s over 100,000 presses per year!) won’t be designed to work with extremely low currents, which you’d need for long battery life. This exact issue caught out some major computer mouse manufacturers when they released new wireless models with extremely long battery life: the switch current was so far below the mouse button microswitches’ minimum wetting current that the switches failed. (They had to have custom switches made with special contacts.) Industrial buttons will be designed for even higher wetting currents than microswitches. Look into “wetting current”.
