For the past few months I have been trying to install either Xilinx ISE or Vivado, from downloads from their site or previous copies I kept that worked on previous Windows installs. All have silently failed when I have run the xsetup.exe etc. After some reading online I found that in the xsetup.bat file found in the \bin folder they run the following test to check for admin priviledges:
%SYSTEMROOT%\System32\net session >nul 2>&1
if NOT %errorLevel% == 0 (
echo ERROR: Administrative permissions are not available. Please restart the command line shell as Administrator.
set EXITCODE=1
goto :end
)The problem is that on my current OS install, the services that this test depends on are not running! If I 'REM' out this test everything works just fine. I guess the Web installer runs the same test and fails accordingly, might have to go for the full download and just modify the .bat file. Hope this might help any others that are stuck.
