Author Topic: Xtal Caps / Measure Caps  (Read 3657 times)
Offline ScutariusTopic starter
« on: December 15, 2010, 02:42:27 pm »
Hi
I have this xtal (32.768kHz) and  the datasheet  saids that CL=15.5pF, my question is if it is right by saying that..
CL= (C1*C2)/(C1+C2) + Cs
Cs= 5pF http://www.oscilent.com/spec_pages/PNDescrpt/Load_Cap.htm
I have no idea why C1 and C2 have the same value  most of times so
12.5-5=  (C*C)/(2*C)
That gives C=15pF
So, if all the above is right, my schematic is a 32.768kHz Xtal with two 15pF caps.
http://forum.allaboutcircuits.com/showthread.php?t=9215
http://www.eetkorea.com/ARTICLES/2001SEP/2001SEP06_AMD_AN.PDF
My second question is how to measure a 0805 cap?, about 1nF or so, my first thought was to desolder the cap and make a filter with a know resistance and due to the Fc know the capacitance, what do you thing? (I need to copy a design I already have must of the values and the schematic)
Thank you!!!
BTW this osc are normally found on watches I am not sure but they usually look that there are no CL, just the xtal
« Last Edit: December 15, 2010, 02:47:16 pm by ee.jcesar »
Re: Xtal Caps / Measure Caps
« Reply #1 on: December 16, 2010, 04:41:51 pm »
wow 81 visits and nobody saids if I am wrong, could somebody take 2 minutes please?
Thanks in advance.
Offline jahonen
« Reply #2 on: December 16, 2010, 04:51:29 pm »
Yes, your reasoning of the crystal load capacitors is correct. They are double to the required load capacitance (excluding parasitics), as they connect in series from crystal perspective. Usually, it might take some tweaking by using a frequency counter to get the oscillation frequency closest to target.
You can measure SMD capacitors with usual LCR-meter, by using SMD tweezers. Or if that is not available, solder some suitable wires to the cap and then plug it into LCR meter (just be careful not to break the terminations).
Regards,
Janne
« Reply #3 on: December 16, 2010, 05:31:15 pm »
thank you Jahonen :D
So I think my multimeter just cant measure small values (not a fluke, no even a good one)
alm
  • Guest
« Reply #4 on: December 16, 2010, 06:42:10 pm »
All multimeters that I know (including Flukes) suck at low capacitance values, that's why dedicated LCR meters (like the AADE kit) are useful. But if you don't own a good DMM, an LCR meter is probably pretty far down your list, since it's a fairly specialized bit of kit.
