Hi all, just a quick question, with (hopefully) a simple answer too!
I'm working on a new lab PSU with decent current capability, to be fed with a high-power 19v laptop power brick. I'm looking at 5-6A at 0-15v or thereabouts.
I settled on using the external pass element circuit shown in the LM317's data sheet, with some tweaks, the biggest of which are the replacement of the shown transistors with what I would consider to be reasonable equivalents. I'm using a 2n3906, and a tip3055 in the place of 2n2905 and a tip73.
My problem is, I can't get the output to go anywhere near the theoretical minimum voltage. I'm running it on protoboard without the negative reference at the moment, so it should go down to 1.25 volts or so at the collector of the pass transistor, but I'm seeing a minimum of 6.5V on the output. I've verified the LM317 ADJ pin is at a few millivolts off ground. Having tested this exact circuit on Multisim gives me the expected output, but in practice, this weirdness happens. As I turn the adjustment pot up, the voltage at the output increases as expected.
Included are my exact circuit, and the circuit drawn in Multisim, working properly.
Any questions about the circuit, as it's assembled, just ask. All the tracks are low impedance, relatively tightly laid out, and with no detectable oscillations going on. All components are running cool. I have tested the circuit both unloaded, and with a significant (500mA or so) load on it. No difference in the output is seen.
