I'm thinking of building a benchtop power supply. (I've been using an old ATX computer supply - which works, kind of, but isn't exactly optimal.)
Please point out anything insane below, if you could.
Background:
I'm an embedded developer, with a background in computer science and Physics. I'm decent at digital stuff, and decent at the underlying theory behind e.g. bandgaps, but analog implementation has always been black magic to me. Given that it's a weak point of mine, I figured I might as well tackle it straight on - but then realized that I didn't have a decent power supply. Hence, this thread.
General parameters:
1. I'm considering my time ~free. Pretty much anything I'm doing here I'll be learning from.
2. Generally speaking, I'm leaning towards lower-level not higher-level. A "use this chip that does everything" design is neat, but I won't learn as much from it, I don't think.
3. Generally speaking, I'm leaning towards analog design over digital design. A brute-force ADC + voltage follower may well be the cheapest solution, but I already have a fair idea about digital design. Not so much analog design.
4. Don't burn the house down.
5. Don't kill myself.
6. I am perfectly aware that building my own power supply is not the easiest way to get a power supply. The easiest method would be to buy one - but then I don't learn as much.
General goals:
1. 2 independent outputs
2. Each adjustable between -12VDC and 12VDC, if possible. (Actually, possibly -15 - 15, for working with op-amps.)
3. Absolute versus relative adjustments, if possible. (In other words, the classic "here's a pot, turn it CW to decrease voltage and CCW to increase voltage" isn't really what I want. I want to be able to easily adjust to e.g. +4.3V.)
4. Separate adjustable current limits, with indicators when current-limited.
5. 1A max output at a minimum.
6. Doesn't die if the output drives it the wrong way.
7. Current limiting should lean towards conservative in terms of transient response. I'd much prefer occasionally having to add a cap to the output if necessary over the output switching on suddenly and the current limiter allowing 10A through for a moment
8. Neutral should actually be neutral. No neutral-side current-limiting, in other words - those don't exactly behave well if you, for instance, have both channels connected to the same circuit.
Sound sane thus far?
Thoughts on how to go about this:
1. I'm thinking of using a standard AC-AC wall-wart transformer as the input. Something enough above 12V peak to allow for regulation headroom, but well below lines (115 here). Probably 3A? This is in the interests of 4 & 5 - means I don't have (as) high voltages to worry about, and means that (hopefully) even if something goes terribly wrong the adapter's fuse will blow. (I.e. none of my circuitry is unfused.)
2. I'm thinking of using encoder decade resistors to adjust output voltages and currents, in the interests of 3. Though, given I haven't been able to find any encoders that both have carries and can have every digit adjusted, I'm not sure how helpful this will actually be. Might be annoying to not be able to e.g. adjust from 3.9 to 4.0V directly.
3. Is there any decent way of doing current limiting that doesn't use a load sense resistor? Or is that the "best" approach?
4. Are there any "standard" architectures for this sort of thing?
5. This will be, of course, connected to a GFI.
I'm thinking "known voltage through adjustable resistor bridge gives adjustable voltage, through buffer amp gives decent-current adjustable voltage, through linear regulator set to keep a constant voltage drop across a variable resistance give current-limited adjustable voltage".
Problems:
1. I doubt I'll find an op-amp capable of 1A at a decent price, so I'll need a transistor (or MOSFET?) follower of some sort - but I'm not aware of any decent ways to do that that cope well with both negative and positive voltages.
2. Ditto, how to get a current-limiting indicator with the classic linear regulator current limiter?
3. I'm worried about potential feedback, as per usual with analog circuitry. In particular, between the two channels.
4. I'm potentially dumping a lot of current across the linear regulator unnecessarily.
Thoughts?
