Author Topic: 16s lithium ion battery charge voltage  (Read 1621 times)
Offline m3vuvTopic starter
« on: September 26, 2020, 10:17:12 am »
Hi all,i am building a 16s battery pack for an ebike,im using 18650 cells,these are standard cells not the phosphate ones,ie 3.7volt per cell,i have a charger that outputs 67.2 volts,will this work for these type of batterys ?,i just wondered if i need to buy a new charger,i already have the bms.,cheers m3vuv
