A couple of years ago, I queried about using a dc power supply in place of a solar array in troubleshooting home solar inverters, most of which, if not all , are grid-tied inverters.
The discussion diverted into the more theoretical aspects, like the non-linearity of the V-I curve and so on, without any useful results or conclusion as to how to construct or purchase such a dc power supply.
Looking on the Internet recently, there is no much information on this subject. Most of the information revolves around, again, on the theoretical side of emulating the solar panel array with a dc power supply and goes deeply into mathematical equations .. in other words, nothing practical from a technician's point of view.
So to keep the objective of this thread as simple as possible. I am interested in troubleshooting inverters from a hardware point of view, that is, if all the components are functional. If they are then the inverter has passed the hardware test.
Not a bit interested in the software side for the inverter or testing the inverter to obtain various V-I curves.
So, what I am looking effectively is to set up a jig consisting of a dc power supply (suitable for all inverters out there to simulate the solar panel array, that is, set up a particular voltage the panels would be producing and the current that be generated or drawn by the inverter), the inverter under test and connected to the appropriate load, with the objective if a problem is present in the inverter to take voltage readings to determine the cause of the problem.
