Author Topic: A stretch of road in downtown Detroit can now wirelessly charge electric vehicle  (Read 1615 times)
Offline boBTopic starter
    • my work www
Sort of like solar freakin' roadways  but, different.  We'll see...
https://www.ibew.org/media-center/Articles/24Daily/2403/240212_EVChargingRoad/fbclid/IwAR2EgkQprSnB9CE2o2SdZoDTF8D-FnDjbQQQuf5dOxxZHergG2jsllbkkDg
Probably fairly inefficient if the vehicle is far above the coil.
« Last Edit: March 17, 2024, 06:12:09 pm by boB »
K7IQ
Online shapirus
  • Country: ua
I have a great idea: there can be powered wires hanging above the roads, and cars would have spring-loaded rods on the top that could make contact with those wires. This way they could charge while moving with the highest efficiency possible, and that would be much cheaper than anything wireless.
Has anyone patented it yet?
Offline jbb
Ooh, ooh! That’s a great idea; an electric vehicle which doesn’t need a big expensive battery. We could put some metal rails in the road for the ground return!
In fact, rolling resistance of a steel wheel on a steel rail is much better than rubber tyre on asphalt road. So how about we take a bus and run it along the rails?
Ideally, it would be nice to separate such a means of transport from the regular roading network. With such a separation we could schedule regular services and avoid traffic jams from overloaded roads.
Offline jbb
Good news / bad news. I did some research and found out that this ‘bus on steel rails’ business was developed in the 19th century.
Good news: we know it works!
Bad news: no juicy patents for us.
Offline radiolistener
  • Country: ua
If you want to charge your electric car on the way, you can use petroleum or diesel AC alternator.
The following users thanked this post: boB
Offline tegan
i  do know this is a joke/meme but charging a tesla with a generator is more fuel efficient then driving the wheel directly im pretty sure since it runs it effectively curve without stop and start.
Online shapirus
  • Country: ua
Yes, also because you can run the engine at its highest-efficiency RPM, and there is much less mechanical losses. Electromechanical drivetrain is widely used in larger vehicles: locomotives, quarry trucks etc.
Online nctnico
That is not done for efficiency as the conversion losses are quite high. Torque to pull away is easier to control with an electric motor. With a direct drive system, you'd need a clutch and for a train that clutch will need to be huge.
