Author Topic: Battery powered 3 phase power for edm machine.  (Read 1388 times)
Offline chrismholtTopic starter
« on: August 29, 2021, 11:31:01 pm »
I would like to put an EDM machine that needs three phase power in my garage. I dont have high current service or three phase power. Is there a solution that might run a three phase machine off of a battery?  I only plan to use the machine for 20min at a time a few times a day at most.
Offline BrokenYugo
Re: Battery powered 3 phase power for edm machine.
« Reply #1 on: August 29, 2021, 11:51:51 pm »
Power requirement?
I guess you could feed the DC bus of a VFD somehow, but running said VFD from the nearest 240V stove or dryer plug (derate something like 50% for single phase input) would probably be a lot cheaper and easier. Or just use this as an excuse to install a 50A welder plug in the garage.
« Reply #2 on: August 31, 2021, 09:21:38 pm »
Note taken.  I will look for other solutions before a battery.
Offline PaulAm
« Reply #3 on: August 31, 2021, 11:22:51 pm »
get a couple hp 3 phase motor and build yourself a rotary phase converter, run it off a dryer outlet.  Simple, cheap, effective.
Depends on how much power your edm draws, but single machines will generally not be a problem.
I run all my machines using a 7hp phase converter with a 30A 240 feed.  It will run most anything up to 5hp before tripping the breaker
Offline BradC
« Reply #4 on: September 01, 2021, 12:24:13 am »
The important question is, why does it need 3 phase power?
One of my neighbours mills "needs" 3 phase, but at the end of the day it's fed into a rectifier to create 415V DC. Does it have an induction motor that needs accurate 3 phase or is it just set up that way because most placed it'd normally be found have 3 phase?
You might be able to give it what it really needs rather than what is implied when you say "3 phase".
Offline langwadt
« Reply #5 on: September 01, 2021, 12:42:38 am »
you need much less capacitance to make DC from three phase than single phase, because it has much less ripple after the rectifier
VFD s that can run from both usually need to be derated quite a bit when run from a single phase
