Author Topic: DIY hydrogen fuel cell?  (Read 5257 times)
Offline adjusttttTopic starter
  • Country: at
« on: December 19, 2017, 07:14:36 pm »
Is it possible to build a hydrogen fuel cell that is capable of producing 2 watts with the same kind of technique youtube user Cody'sLab used in this video? But have it produce 2 watts.
I read in the comments that he didn't have the electrodes close enough together and that that could decrease the efficiency.
Or this is completely impossible since I calculate that it would need to be 2778 times more efficient than his.
I know that even this is possible it is extremely inefficient and other bad things but I am after the unlimited charge/discharge cycles this could or so I think. thanks
Offline Belrmar
Re: DIY hydrogen fuel cell?
« Reply #1 on: December 28, 2017, 08:03:42 pm »
welll..... for the amount of platinum that it would need , its not worthit to wonder around that, pretty wastefull of a precious metal and it wouldnt efficient at all
Offline amorphous
« Reply #2 on: December 29, 2017, 03:22:24 pm »
Yes, it's possible using this method. This is similar to how the first fuel cell was made in 1839. You would need a lot of platinum to do it this way. Modern fuel cells use platinum nanoparticles on carbon micro-particles for very high surface area fuel cells. If you do it the modern way, you can get very high power densities. For example, the Toyota Mirai fuel cell car uses a fuel cell stack that has a power density of 3kW per liter. So, if you wanted 100kW peak power, you would need a fuel cell of this type that is 33L in volume.
This is a nice little demonstration and everything he says in the video is true. It is important to note that most fuel cells (including the one in the Toyota Mirai) only combine hydrogen and oxygen to make water and electricity. Splitting water to make hydrogen and oxygen in large amounts and for a long time requires a different setup than a "regular" fuel cell.
I worked on fuel cells for over 10 years. They are a lot of fun and can do some amazing things, and are very energy efficient, especially compared to internal combustion engines.
