Author Topic: Energy Magnet Motor fan used as Free Energy Generator  (Read 13122 times)
Offline baastrupTopic starter
« on: January 20, 2017, 09:19:24 pm »
Is this even possible?
https://youtu.be/jiAhiu6UqXQ
Offline Kremmen
Re: Energy Magnet Motor fan used as Free Energy Generator
« Reply #1 on: January 20, 2017, 09:24:45 pm »
No, it is not possible. All these videos are fakes.
Nothing sings like a kilovolt.
Dr W. Bishop
Offline The Soulman
  • The sky is the limit!
« Reply #2 on: January 20, 2017, 09:29:25 pm »
He has solved the worlds energy supply for generations to come OR he's an shameless fraud
misleading people to get more youtube views.  :rant:
(obviously the second option..)
« Reply #3 on: January 20, 2017, 09:31:14 pm »
What about this one?
https://youtu.be/VMdS65_E_X4
Offline The Soulman
« Reply #4 on: January 20, 2017, 09:39:32 pm »
Yes that one works, it's a battery and will run out and leave you with hazardous waste.  :-//
Offline iaeen
« Reply #5 on: January 20, 2017, 09:39:56 pm »
Looks like he made a (very crude) battery. Like all batteries, to will go flat once the chemical potential energy is depleted.
By the way, the energy doesn't come from the salt water (or some magic ferry). It comes from the aluminum corroding.
Offline Lord of nothing
  • Country: at
« Reply #6 on: February 07, 2017, 02:43:14 pm »
How about an Magnetic Engine for long therm Energy Source?
Made in Japan, destroyed in Sulz im Wienerwald.
Offline hayatepilot
« Reply #7 on: February 07, 2017, 03:03:24 pm »
What is a "magnetic engine" supposed to be?
Every electromotor and generator uses magnetics but they don't produce energy, they convert it from mechanical to electric energy and vice versa.
And with every conversion you loose some energy to heat since the efficiency can't be 100%.
Greetings
  • Country: at
« Reply #8 on: February 07, 2017, 03:05:24 pm »
 :-+ like all other...
But how long can it run until the Magnets loose there Power?
Offline Delta
« Reply #9 on: February 07, 2017, 03:36:05 pm »
Magnets don't have "power" :palm:
  • Country: at
« Reply #10 on: February 07, 2017, 03:42:40 pm »
 :-// sorry its hard to translate.
Offline hayatepilot
« Reply #11 on: February 07, 2017, 07:07:31 pm »
Magnets in motors and generators don't loose their strength. No matter how long or often you use them.
  • Country: at
« Reply #12 on: February 07, 2017, 07:09:45 pm »
So it mean a Magnet Generator can produce Power over a long time?
Offline hayatepilot
« Reply #13 on: February 07, 2017, 08:08:00 pm »
Yes, as long as you put in mechanical energy, they will produce electricity.
Almost all electricity we use is produced this way. Solar cells are the only notable exception
But all of those "magnet motors" (like the one in the video in the first post) which supposedly produce energy without input are ALL fakes!
I suggest you read this page: https://de.wikipedia.org/wiki/Perpetuum_mobile
Offline james_s
« Reply #14 on: February 07, 2017, 08:23:41 pm »
Why do people even ask about this stuff? No, it's not possible. Any system that claims to be putting out more energy than is put in is either fraud, measurement error, or a source of energy is not accounted for. You cannot violate the laws of energy, period. There is money in creating a convincing scam for those who believe otherwise though.
Offline james_s
« Reply #15 on: February 07, 2017, 08:28:30 pm »
That isn't entirely true. It's common to have to remagnetize the magnets in old electric motors and other applications. A few years ago I helped someone build a magnetizer to refurbish the motors in vintage toy slot cars. The magnetism is not consumed, but it does fade with age.
Offline hayatepilot
« Reply #16 on: February 08, 2017, 12:33:38 pm »
Yes, that is true of course. I wanted to simplify things since he doesn't seem to be very competent in physics.
The modern neodymium and ferrite magnets can hold their strength nearly indefinitely as long as they are not heated above their intended usage temperature.
Those old magnets were probably made out of steel which looses its magneticity pretty easily.
Offline ziplock9000
« Reply #17 on: February 08, 2017, 06:21:06 pm »
Ironically his almost 20 million hits is free money to pay for energy.
Offline james_s
« Reply #18 on: February 08, 2017, 07:13:07 pm »
I suspect that was his goal all along, get people to watch his scam, make money.
Offline Codebird
« Reply #19 on: February 09, 2017, 04:09:03 pm »
If I had a free energy machine, I wouldn't be posting it on youtube. I'd be deciding between seeking investors or earning myself a Nobel.
Offline Gregg
« Reply #20 on: February 11, 2017, 02:23:36 am »
I'm surprised the Acme Corp doesn't sell a free energy device (yet).
http://dangerousminds.net/comments/fabulous_collection_acme_products_bugs_daffy_and_wile_e._coyote
The first rule of free energy is: "There is no free energy"
The second rule of free energy is: "Just because someone believes something doesn't make it true"
The third rule of free energy is:"If you really find free energy, shut up about it and develop it very privately"
Online CatalinaWOW
« Reply #21 on: February 11, 2017, 03:36:52 am »
In fact, if you are ever in a position to invoke rule three, don't sell it as free energy.  Sell it as a very good battery, or a very fuel efficient motor or whatever.  You will make plenty of money that way and avoid endless grief from those out to prove you wrong.
Offline moz
« Reply #22 on: February 23, 2017, 11:24:57 pm »
I reckon you'd be better off choosing life. Keep it secret until you know it works, put together a set of documents describing everything you know, then pick a date. Spam the whole thing as widely as possible as fast as possible, so there's no question that anyone will be able to grab the info and keep it secret. You'll still get your world fame and Nobel, but you won't be part of the "let's keep all of this secret" project by someone else.
Forget annoying Shell or a Saudi oil billionaire, Russia is a petro-state and Putin owns a big chunk of their oil companies. Good luck persuading him to leave you alone if you have a secret free energy source that threatens to implode him and his country.
Or, you know, make a youtube video and put it up next to "12 property investing secrets that will make you a millionaire". That can work too.
Offline james_s
« Reply #23 on: February 24, 2017, 12:29:28 am »
I don't see that as being a big problem. It has been said that oil is far too valuable to be burning it as fuel. It has countless uses and nearly unlimited demand. If we stopped using oil as fuel cold turkey it would cause economic consequences but if it was phased out over a reasonable period demand would still be enormous.
Offline Red Squirrel
« Reply #24 on: February 24, 2017, 03:16:17 am »
When I was this kid I had this idea that if you were to have a wheel with 4 magnets on it, and then 3 magnets on the part that does not turn, or other uneven number of magnets, one magnet would repel the other, sending the next into the path of another and so on and it would spin forever.   I also had an idea that you could make an electric car if you had a solar panel power a light bulb, and a small battery that would be used only for starting by turning on the bulb.
Then I grew up and realized none of this was possible.   :-DD  Damn laws of thermodynamics!  :scared:
