Author Topic: Need Help Troubleshooting My First SMPS Design (220VAC to 12V 60W)  (Read 890 times)
Offline synacleTopic starter
  • Country: tr
    • Synacle Blog
Hi everyone,
I’m working on my first switch-mode power supply (SMPS) design. It’s supposed to convert 220V AC input to 12V DC at 60W output.
I’m not an electronics engineer and I don’t have formal training in this field – I’m just a hobbyist trying to learn.
The transformer was custom-wound by a manufacturer in China. Here are the specs:
Core: EE33
Primary Inductance: 82 µH
Primary: 15 turns, 0.65 mm wire
Secondary: 3 turns, 1.5 mm wire
Auxiliary: 5 turns, 0.2 mm wire
When I powered up the PCB for the first time, the transistor and Rsense resistors burned out instantly. I suspect my snubber/clamp circuit calculations might be wrong.
I’ve attached a hand-drawn diagram of my transformer (see image).
Could you please help me troubleshoot this design? I’d appreciate explanations in simple terms since I’m still learning.
Thank you very much!
Offline Magnethicc
  • Country: il
Re: Need Help Troubleshooting My First SMPS Design (220VAC to 12V 60W)
« Reply #1 on: September 06, 2025, 05:50:56 am »
Upload PCB too, it could be wrong connections.
I see no soft-start circuit - could be too high duty on the flyback x'mer saturating it and blowing up the FET and sense resistors.
see page 22 in https://www.ti.com/lit/ds/symlink/uc3842.pdf and follow their guidelines.
Online temperance
« Reply #2 on: September 09, 2025, 12:16:30 am »
The primary inductance is probably too low.
Given the primary inductance, the di/dt is around 3.7 A / µs with an input voltage of 300 V. With 82 µH primary inductance and an on time of 1 µs, you are trying to transfer 115 W to the output when switching at 100 KHz.
The primary inductance must be around 450 µH for a DCM mode converter.
With 450 µH primary inductance, the transferred power is 77 W when operating at 100 KHz with an on time of 3.5 µs for the primary switch.
« Last Edit: September 09, 2025, 12:44:49 am by temperance »
