I bought a Hydropro Premium 14 swimming pool heat pump heater at an auction. Output 14kW. The controller was dead, but a new replacement included and just tried it, new controller doesn't communicate over the serial bus, error.
Anyway, pretty simple inside, connect mains to compressor and fan and off it goes. In this mode it is actually cooling the water, and gets impressively cold. Only using a few gallons of water in a bucket with a small circulating pump.
There is a 4 way valve, operating that and changes to heating. Again impressive performance on the limit water, hets too hot to put a finger on the compressor pipe so >60C.
Measured consumption at 240V was about 11A on cooling and 15A on heating. This ties in reasonably well with the stated consumption.
Question, why is the heating consumption greater than the cooling consumption? The four way valve just reverses the direction of gas flow through the compressor?
On a very quick test it would seem that these swimming pool heat pumps are a good thing. Air to water so easy to get into the house to use the heat. What needs some more testing is how well it works with an air temperature below 10C, not at 25C.
