Hi
I just received a "60w" panel and tested at ambient temperature before the glass got hot, in full sun, no clouds, 11:35 am, Qld.
The product label states 21.6v VOC and 3.77A ISC, Vmp 17.7, Imp 3.39, 60w.
When I tested the panel the VOC is 23.2V and the ISC is only 2.1A.
When the panel is attached to a 10ohm 200w power resistor the panel only delivers 1.8A at 18v, or 32 watts, when cool at midday. I should have measured the solar irradiance but forgot.
These panels are made from 125x125 Sunpower Maxeon cells cut into 1/3 (125x41); 36 joined together in a 36 cell string.
The spec for the Sunpower Maxeon 125x125 cell is 6.28A Isc. Dividing this by 3 = 2.1A. This is the max SC current produced by the new panel.
According to some specs I found online, the full 125x125 cells theoretically produce 0.687v Voc. Multiply that by 36 cell in the panel and you get 24.7V, similar to what I measured 23.2V, plus some drop across the diode.
The label on the panel and the rated output cannot be correct. Seems like half the amps are missing!
Comments wanted before I question the seller.
Thanks
