Dear Engineers,
We are using a Vicor DCM3623T75H26C2T00 DCDC module for a spec of
Vin=42-59VDC, Vout = 24V 5.8A.
The Module sits on a PCB, which is itself in a large-ish, sealed enclosure. The module will dissipate 17.2W of power at full load. The DCDC module’s internal temperature must stay below 110degC.
No cooling fans are allowed, just a heatsink.
DCM3623T75H26C2T00 DCDC module datasheet:
http://www.vicorpower.com/documents/datasheets/DCM3623x75H26C2yzz_ds.pdfThe DCDC module’s Rth(junction-case) is 1.5degC/W.
With the module’s power dissipation of 17.2W, the ambient temperature inside the enclosure will be 67 degC, we know this from temperature tests.
The heatsink used is the “180AB” by abl-heatsinks (datasheet below). Dimension is 215mm x 170mm x 7mm (height). Heatsink Rth = 0.3degC/W.
Anyway, DCDC Module internal “junction” temperature will be 67degC + 1.5*17.2W + 0.3* 17.2W = 98degC.
Since we are not using a fan, we do need this very large heatsink. This is unfortunate. Would you agree with these calculations?
180AB heatsink datasheet:
https://www.abl-heatsinks.co.uk/index.php?page=extrudedproduct&product=170We are starting to think that since we are doing it fan-less, and the heatsink size needed is so big, we would actually be better off doing this with four paralleled Flyback converters instead(..with one single feedback error amplifier so they all share output current equally). Then the heat is spread between the four flyback converters, and the overall solution size will be less. What are your thoughts?
