Author Topic: PCMC+PSFB on STM32 is it possible?  (Read 17926 times)
Offline Sniper1
Re: PCMC+PSFB on STM32 is it possible?
« Reply #25 on: June 18, 2025, 08:14:56 pm »
Up to now I have been using STM32G4 to control phase-shift full-bridge (PSFB) in voltage control mode (VCM). Now I would like to add peak current control mode (PCMC) for better performance, but it appears that none of STM32G4 is capable with such capabilities. At least I was unable to find the way for it.
Did I miss something? What is the best way for such digitally controlled power supply?
I have thought about some hybrid, a digital+analogue approach by coupling STM32 with something like UC28950, but I still believe that should be a better way...
Thanks,
Did you manage to make it work in the end?
Offline Alex-labTopic starter
« Reply #26 on: June 18, 2025, 10:48:11 pm »
This config seems to work, but I’m wondering if it can be done more efficiently, reliably, etc.
No, this is the correct method.
Not yet, I had to put off this project so far as I was unable to achieve reliable operation.
Offline Sniper1
« Reply #27 on: June 19, 2025, 07:18:01 pm »
ok
I am also going to implement PSFB on a STM32.
Did u use a MCU with a High resolution timer or not?
or rather did you try using normal timers or the special one?
« Reply #28 on: June 19, 2025, 11:55:33 pm »
Originally, my project had been using F1 where I used regular timers. After that it evolved through F3, F4 to G4 where HRTIM is used. All that story is about voltage mode control. For current mode I have not found the solution yet as I have no time at the moment. I am still thinking about digital-analog hybrid approach.
Offline Sniper1
« Reply #29 on: June 23, 2025, 05:34:00 pm »
I am starting with G4 since i am not the best programmer and as of now i am at the design stage .
Offline uer166
« Reply #30 on: June 23, 2025, 09:29:18 pm »
I would highly recommend HRTIM, but not for its' "high resolution" feature, you can totally ignore that most of the time.
The real value is the output set/reset crossbar that can be driven from many different sources (comparators, other timers, etc), and all HRTIM instances can be synchronised together quite easily.
