Greetings. I aquired a retired scooter quite a while ago and finally decided that I should give it a more useful purpose than catching dust in the basement.
The ESC looks like any generic e-bike controller, but I can't find any information on it. The model number is: JFKSF-M5
I suppose hijacking the bus system to activate it would be too much of a hassle, so getting a new controller is propably the most sensible approach?
The thick plug as seen on the pics is the motor connector. In addition to the 3 thick phase pins it has 8 tiny pins. What could they be? I suppose that there is no standardization whatsover with the pinouts so I would have to cut the connectors off and rewire for a new controller.
Any recommendations on cheap, compatible BLDC controllers (or on ways to make use of the OEM one) would be appreciated. Thank you.
