The end result is kind of the same. Try increasing R7 to about 5Ω
to check for effect. Double check that R7 is likely to be 3.3Ω by measuring it.
Im assuming that the PSU is already capable of smooth current limiting? no rattles or squealing.
What bothers me a bit is that primary snubber current is also being sensed, adding to leading-edge-spikes.
From the Osemi's data PDF,
https://www.onsemi.com/pdf/datasheet/sg3525a-d.pdf"An alternate approach is the use of the shutdown circuitry
of Pin 10 which has been improved to enhance the available
shutdown options. Activating this circuit by applying a
positive signal on Pin 10 performs two functions: the PWM
latch is immediately set providing the fastest turn−off signal
to the outputs; and a 150 A current sink begins to discharge
the external soft−start capacitor. If the shutdown command
is short, the PWM signal is terminated without significant
discharge of the soft−start capacitor, thus, allowing, for
example, a convenient implementation of pulse−by−pulse
current limiting. Holding Pin 10 high for a longer duration,
however, will ultimately discharge this external capacitor,
recycling slow turn−on upon release."
