Hello,
This is my first post, apologies if this has already been covered elsewhere, but my quick search didn't yield any results.
I would like some advice on the correct approach to the following:
I have a 24V solar panel that I would like to use to power a 5V radio board. This board is very sensitive to over voltages, which I found out the hard way.
I have a small no-name eBay Special DC-DC buck-boost converter that I am hoping to use to regulate the voltage swing of the panel throughout the day.
The converter works well until the input voltage drops down to around 3V and then its output spikes up to about 30V. When this occurs, I seem to be measuring about 10mA from the output.
The voltage in this raised condition will change if I adjust the value of the trimpot used to set the nominal output voltage of the DC-DC converter.
This doesn't seem like alot of power, but I would rather not have to replace the diodes on my radio board again.
I am currently testing this with a variable DC power supply and handheld multimeter.
I know I could buy a 5V panel and be done with it but couldn't resist the chance to learn something for once.
My questions:
Is this a little surge from the inductors in the converter collapsing? Would a standard TVS or Zener Diode be appropriate on the output?
Is this caused by some leakage within the cheap DC-DC converter that could be remedied with some filtering?
Since I am going to the trouble of sourcing discrete components, what would be an eloquent way of clamping this? It would be more interesting to set up a voltage-controlled switch rather than just dump the power through a zener.
Should I instead focus on clamping the input voltage? I am not seeing this rise in voltage when I turn off my DC Supply, only when I set it to hold at about 3V.
I don't need a complete schematic for any solutions, but if anyone has any suggestions on what a good approach would be or keywords to search for, I would very much appreciate it.
Thanks
-BT
