Hello,
I got an idea that when I have a 6V, 1.5A(Max. Contionious) battery with an voltage follower opamp, I cantprovide more current and more outpu voltage with lower impedance in theory that I know. My question is do you think it is possible. I drive a dc brushed motor and i would like to compansate inrush current and the high voltage drop issue on the battery.
I attach one example circuit. The question here is if i set the zener to 5.2V as referance voltage. How will the current supply amplified, battery will consume less current or the inrush current will be limited? I think I need a transistor to limit the inrush current.
