I'm on a Siemens PLC output board (board ref 812 2298 01-, PLC model Simatic S5-100U), the "fault" led of that board is on when using the PLC. It is not a slot problem, other board worked fine in the same slot.
I identified the faulty part, it is a SMD in parallel with the input cap on the power supply rail, and it is in short circuit.
The package seems to be a SOD-80, marked "2222" all around the part. Probably a surge protection part, but I can't find any informations about it.
Here are some pictures :
https://www.dropbox.com/sh/fn01nqzu8qwz9v4/AACLUskmBHj4l6z6YH_wRcdTa?dl=0Furthermore, the 10A fuse is blown, is there a way to determine if it is a fast acting or a slow blo ?
Thanks !
