I recently switched to Lithium batteries in the RV. They can accept charge current at up to 400A, but my primary charger is limited to 125A. Because I charge with a a noisy generator, I need to minimize generator run time by increasing the charge rate.
To achieve that, I added an 80A switch mode charger. It worked great for a week, but suddenly the battery monitor system (BMS) for the lithium began to spit errors. It was the 80A charger. When I removed the charger, the errors stopped. The errors were from the temperature monitors. I was certain the temperature was not excessive as the error code claimed.
However, the 80A charger was still producing it's rated current and voltage. I suspected it was producing noise that was interfering with the BMS temperature monitoring network and sensors.
When I opened the charger I found that the snubber capacitor was split in two. When I got home from vacation, I replaced the snubber cap. The cap was definitely bad (open).
I've attached a schematic from the patent for the device (PD9280). The snubber is C24.
My problem is that I looked at the output before and after the repair and it looks unchanged. The switching frequency is 4.5 kHz. Every 200 to 300 ms there is a ringing spike of about 2 volts peak to peak. It rings down and decays in about 2 ms with about 10 cycles of ring (I could put a scope pic up if it helps. This is with no load.
I haven't tried reconnecting it, and I don't have any easy way of testing it with a load until I reinstall it.
I'm just not familiar enough with the noise characteristics of switching supplies to be sure, but 2 volts on a nominal 12v system seems excessive. I've also attached a schematic of the output with its filtering. The filter caps and choke seem OK.
I'd appreciate comments on whether the bad snubber might have caused other damage. Is the noise level reasonable in light of the filter circuit shown in the attachment? How can I reduce the switching noise from the 2 volts P-P to a few hundred millivolts. I don't need perfection, but I'd really like better than I'm seeing now. Thanks.
The patent link is:
https://patents.google.com/patent/US7782002B2/en?oq=7782002The patent describes circuit operation and has most of the component values listed at the very end.
