Thanks for all your input. The unit is identical to the one shown in the video posted below. Yes, it's a Chinese unit
. One that cost a little too much to just throw away.
Are you pretty sure the short is on the CB ? Can you isolate which supply rail is shorted ? It'll help also if you can rule out whether the power section (IGBTs more likely, maybe MOSFETs) is shorted out too.
I'm reasonably certain that the short is on the board as I've had
most of the plugs disconnected and found there is still excessive current draw. The other plugs I'm not comfortable with disconnecting with the system powered up. The last thing I would want is for something to latch up and go bang. At present, I've had to resort to breaking the tracks and have managed to identify a 2 ohm short. I've narrowed it down to the left hand side of the board (as per the original post) but haven't looked at it since. I broke the circuit into several elements and found the 2 ohm short to ground appears in two regions. I'll have to do some further investigating.
as i can see on the photo, near the number 54 and 59 yellow transformers, you seem to have 4 outputs of somekind, pull the 4 plugs, white balck, green black, blue black, gray black ... do a current test
These drive the HV inverter gates. I've had them disconnected and it had no impact. I'll see if I can get my hands on a decent power supply / voltmeter and give your test method a go.
I see that you have a lot of work with this welder ! i guess it's a Chinesse brand, did you weld on dc normally ?
I can't answer that for you, it's a friends welder.
This seems familiar.
Back in 2006-07 I used to inspect/modify units like these before shipping. Do you have any more photos of the sides with the lid off? Any part numbers? Cos they're are a generic, rebadged unit and a schematic might exist.
I have a schematic here but it only details the main driver and the outputs of the control board. The part number on the board is WSME 200C. WSME 200 is a common part number for Chinese welders but it appears that they've evolved somewhat, nothing that I can find resembles what I have here.
I assume when you say regulator, you mean one of the devices stuck to the heatsinks in the middle of the board?
If i remember there is a thick conformal coating or varinsh on these boards so if you want to start probing around best get a sharp set of probes!
Yep, those are the ones. A pair of 7815 linear regs. It's the one obscured by the other heatsink (right hand side) that is rising in temperature. Yes, that varnish is everywhere and creates a real mess when trying to desolder anything. They've coated the ICs with it as someone mentioned above. It's shrunk back so the embossing on most chips is visible. The large 14 pin DIPs are D flip flops and the 8 pin DIPs are mostly Op amps.
