Author Topic: ATX motherboards: early power-on circuitry?  (Read 897 times)
Offline WhalesTopic starter
    • Halestrom
« on: May 31, 2020, 11:19:12 am »
I have a cute little passive atom x86 board out of a piece of proprietary rack equipment.  I want to use it as a small computer but it won't turn on.
No useful make or model markings.  I suspect part of the proprietary wiring harness is needed to turn it on, but I don't have any of that.
The LPC chip gets quite warm (Nuvoton NCT6776F) and one 5V rail + some 3.3 appears (the unit only takes a single 12V input).  None of the main power supplies (eg for the CPU) turn on.  No sounds, squeals, lights or jolts as I short any of the pins labelled as FRONT_PANEL (looks like the same 9-pins of 2.54 that you get on desktop boards).
Q1: How is early-turn on handled on ATX motherboards?  Is the power switch header wired directly to a power supervision chip, does the LPC handle it, etc?
Q2: Any public ATX motherboard schematics or info that I can learn from?
    • Halestrom
Re: ATX motherboards: early power-on circuitry?
« Reply #1 on: May 31, 2020, 11:49:55 am »
Buzzed out what I thought was the front panel sw pin & found it went to pin PSIN# on the LPC chip.  Hooray, I always start getting somewhere just I as I need to get to bed for work tomorrow :P
Any and all advice appreciated.
Offline coromonadalix
« Reply #2 on: May 31, 2020, 03:51:44 pm »
post photos of your atom board, any brand or markings ?
Offline fzabkar
« Reply #3 on: June 01, 2020, 07:07:23 am »
Identify the ground pins in the 9-pin header.
Apply power and determine which pin(s) have a standby supply, eg 5VSB or 3.3VSB.
Determine if any of the standby supply pins are actually pulled up to a standby supply via a resistor. This will probably be the Power_on pin.
Short this pin to ground, either momentarily, or by holding it for a few seconds as you would a normal desktop PC.
Online magic
« Reply #4 on: June 01, 2020, 09:10:22 am »
I once had a bad PSU which didn't assert the POWER_GOOD signal and the board just sat quiet and kept waiting for it.
    • Halestrom
« Reply #5 on: June 01, 2020, 11:54:32 am »
Thanks for the tips.
It turns out the LPC is very well documented in a public datasheet, complete with logic gates/requirements for boot signals.  Going to hunt these signals out one by one.
