Author Topic: bad tv  (Read 7921 times)
Offline kjn4685Topic starter
bad tv
« on: December 02, 2015, 01:19:48 am »
Hi guys
I am working on a 26 inch tv model # va26lhdtv10t. I have a chip that I can't find a datasheet on the chip is my5380ltu. I would appreciate it very much if you guys could help me find one. Thank you in advance.
Lou
Offline tec5c
Re: bad tv
« Reply #1 on: December 02, 2015, 04:44:56 am »
Can you take a photo of said chip?
Re: bad tv
« Reply #2 on: December 03, 2015, 07:11:44 am »
hi guys
I have tied to put pic on the forum for about a hour with on results. I have used these pixels rates 600*480 800*600 1024*768 1920*1080. I know there are more than this. I hope you smart ee's out there can give me some help. |O.
Lou
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
Re: bad tv
« Reply #3 on: December 03, 2015, 07:19:37 am »
Do you have an account with a photo hosting site like Flikr?  (I use SmugMug, which is similar.)  I think the easiest thing to do if you have one is to use the 'insert image' tool (under the bold text button above left) to post a link to the photo on a site like that - there should be a way to get an embeddable link to the image from the hosting site.  As for directly uploading to this site, I'm not sure if you can or not as I've never tried.
Good luck!
-Pat
Offline Rasz
    • My random blog.
Re: bad tv
« Reply #4 on: December 03, 2015, 10:20:03 am »
hi guys
Lou
consider it a turing test of sorts, I dont think you are capable of fixing a tv if you cant figure out simple file upload :(
Offline Deathwish
  • Country: wales
Re: bad tv
« Reply #5 on: December 03, 2015, 10:59:27 am »
hi guys
Lou
Why does it fail to upload?
filesize probably  (  maximum individual size 1000KB ) , not resolution
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
Offline Ian.M
Re: bad tv
« Reply #6 on: December 03, 2015, 11:11:06 am »
AAGH!!! It *IS* a Turing test.   Hopefully the O.P. has more active brain cells than the idiot who emailed a dozen  2MB JPEGs of a small event that few of us had attended CCed to his entire address book, then couldn't understand why he was less than popular with the majority of us who were at that time on dialup!
On other forums I frequently have to contend with 200K file size limits.   Its not an issue if you have a graphics package that can control the file size when saving JPEGs.   Hint: save for Web/Email or use IrfanView's RIOT plugin, but always archive the *ORIGINAL* file if you want to keep it.
Offline JacobPilsen
  • Country: cz
Re: bad tv
« Reply #7 on: December 03, 2015, 06:45:02 pm »
Does main PCB has some marking ???
i.e. Tq9cbzk06002 715g3531-2
Qiuck look into VA370M Service Manual: It looks very similar to LG Service Manual.
Re: bad tv
« Reply #8 on: December 03, 2015, 08:38:58 pm »
The board has a # 715g3531-1
Lou
Re: bad tv
« Reply #9 on: December 03, 2015, 10:02:43 pm »
Here is the pic
Re: bad tv
« Reply #10 on: December 04, 2015, 04:24:02 am »
Hi guys
I need a datasheet for this chip. I appreciate your efforts , but like I said I need a datasheet.
Thank you very much for efforts.
Lou
Re: bad tv
« Reply #11 on: December 04, 2015, 04:27:57 am »
Hi there again.
Does anybody out there have a data book on said chip.
Lou
Offline JacobPilsen
  • Country: cz
Re: bad tv
« Reply #12 on: December 04, 2015, 05:36:47 pm »
It's one of those dodgy noname LCD drivers/processors, right?
Not at all.
It's MediaTek MT5380 with ARM core.
Used in Haier HL32R1, HL32K1, HL32XK1.
Re: bad tv
« Reply #13 on: December 04, 2015, 08:47:27 pm »
I want to thank you guys very much for help. Even thought I do not have a datasheet.
Lou
