Author Topic: BF451 replacement  (Read 2054 times)
Offline WawavounTopic starter
  • Someday I'll get you, Red Baron !
BF451 replacement
« on: May 09, 2022, 11:53:49 am »
Hello there
Any idea for an easy to find replacement for BF451 transistor ?
Case TO92
PNP
Ic 25 mA
VCE - VBE 40 V
Hfe 30-90
F 350 MHz
Thanks.
Philippe
Offline strawberry
  • Country: lv
Re: BF451 replacement
« Reply #1 on: May 09, 2022, 12:37:13 pm »
« Reply #2 on: May 09, 2022, 12:58:26 pm »
Thank you !
I even think I have that in the workshop...  :)
Offline Jacon
« Reply #3 on: May 09, 2022, 03:40:04 pm »
It depends - BF451 was a HF transistor - it has Ccb = 0.32pF typ.
BC5XY are universal transistors, with Ccb almost 20x larger !!!
So - what is the use case for it?
« Reply #4 on: May 09, 2022, 04:42:39 pm »
It is for mixing sync pulses and video signal.
BF451 for sync pulses and 2N2219 for video signal.
Offline mariush
« Reply #5 on: May 09, 2022, 05:00:11 pm »
If the voltages are under 30v , NTE2401 maybe ? https://www.digikey.com/en/products/detail/nte-electronics-inc/NTE2401/11652069
Not to-92, but soldering 3 copper leads to the terminals would not be hard.
Offline strawberry
  • Country: lv
« Reply #6 on: May 10, 2022, 06:06:15 am »
