I am trying to interface TTL circuitry to an old piece of equipment (a Texas Instruments PC-100C printer cradle). That one has two supply rails, at (approximately) -10V and -15V; logic 0 is, of course, 0V, logic 1 is -10V on some and -15V on some others. If these were unidirectional lines, I could do the trick with just some variant of max232, but they are not, they are bidirectional. If they had only one supply, I could invert the TTL logic, make a level converter to, say, 10V, then connect the TTL Vcc to the old equipment's Vss and power the TTL circuit from a battery. Digging around, I found a patent to convert TTL to ECL levels, but (a) that appears too complicated (ECL working in the active region of transistors and all that), and (b) not sure it will actually work for bidirectional signals.
Help?
