Hi guys, I have got a Bose L1 classic model in for repair. There was some saltwater splashed on to the unit. Previous tech had a look and gave up saying there was too much corrosion. I had a look inside and there was very minimum to no corrosion. I noticed that there was a short between two pins near a connector with carbonized PCB(CN120A Page #26 between pin 4 and 5). I used a dremel to remove the carbon and measured the resistance the short was now removed. I cleaned the connectors. This was on the front panel board, only place where the salt water could have effected.
After powering on, the unit keeps shutting down and then starts back up(keeps cycling) due to high current draw. I should mention I have got a 100W bulb in series with the input. I removed the power supplies leads to the amp section and only had the preamp/microcontroller board attached (the board which supposedly was splased with salt). All the voltages measurements taken seemed okay and the unit did not shut down. The current draw from the mains were a bit high still.
I had a look at the other power supply boards which powers up the amplifiers (page 20 of the pdf). All these were connected at the time just not connected to the amplifier section. I noticed charring of R507 and R508 both have failed open. Z501 and Z502 have shorted out. The two mosfets Q501 and Q502 have both failed open. (I have marked in the photo). What could be the cause of this? I checked the amplifier sections thinking something might have shorted out. Everything seemed to look in order. Could the high current draw be caused by these components being failed? I noticed that all the boards needs to be connected for stable voltages. I noticed by removing this power supply board the voltage ouputs of the aux power supply outs have gone slightly up.
I hope some one could help me understand this power supply, and what might have caused this components to fail. Any idea on what to look for next.
I have tried attaching the pdf of the service manual in this post but it doesn't seem to upload. Here is the link for the file its in the first post:
https://music-electronics-forum.com/showthread.php?t=41558Thanks in advance.
p.s I came across this blog which has got some good pictures of the unit
https://lensprojects.com/2016/08/25/bose-l1-repair/
