Good evening; I'm having a problem with a TL866 programmer. When I install my PIC16F873A (SOIC28) (new); I have an error code displayed, and I can not do anything; neither read nor program it. The support is new, and the direction of the integrated circuit is correct, as well as its legs that touch the contacts correctly. I attach photos. Do you have an idea?? Thank you for you precious help
