Author Topic: Chinese Power Supply kit troubleshooting :problem to ask for ...  (Read 3582 times)
Offline Ahmed KhouajaTopic starter
  • Country: tn
« on: November 03, 2019, 05:16:53 pm »
Hi guys
Like most people , i have problem with this kit wich is i get -0.45v when the V and A pot are fully anti-clockwise and i get only 5.1V when the V and A are fully clockwise.
I checked almost the whole circuit with the help of schematic that is made by "Netzener" .
I'm using 12-0-12 , 3A transformer...
So guys can you guess where is the probleme? I will attach a pdf file wich can help you understant the whole circuit...
The problem is this page :
865830-0
between Vout- and R15 i cant get 11.4V , i only get the half of it wich is 5.2V and in the output i only get 5.2V when the pots are fully-clockwise ...
When the pots are fully anti-clockwise , the output give -0.45V !
Any suggestion ??
Thank you .
« Last Edit: November 03, 2019, 05:38:00 pm by Ahmed Khouaja »
Offline xavier60
Re: Chinese Power Supply kit troubleshooting :problem to ask for ...
« Reply #1 on: November 03, 2019, 07:24:02 pm »
Is the reference voltage correct?
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
  • Country: tn
« Reply #2 on: November 03, 2019, 10:06:51 pm »
Yes, its correct !
Offline xavier60
« Reply #3 on: November 03, 2019, 10:10:27 pm »
What voltages are on pins 2,3,4,6 and 7 of U2 with both Pots fully clockwise?
Offline m3vuv
« Reply #4 on: November 04, 2019, 03:21:00 am »
this looks like a hyland psu,can be made to work ok with mods,check this link out.http://www.paulvdiyblogs.net/2015/05/tuning-030v-dc-with-03a-psu-diy-kit.html
  • Country: tn
« Reply #5 on: November 04, 2019, 05:30:43 am »
PIN 2,3: 5.07V
PIN 4: -5.6 V
PIN 7: 30.1V
PIN 6: 5.2V
And i feel that the problem is in this area , maybe i'ill replace this U2 with another new TL081 ...
  • Country: tn
« Reply #6 on: November 04, 2019, 05:33:45 am »
Yeah with some modification it will defintly works, but i want it to work as it is , its a challenge for me   :o |O :-/O
Offline xavier60
« Reply #7 on: November 04, 2019, 06:46:30 am »
PIN 2,3: 5.07V
PIN 4: -5.6 V
PIN 7: 30.1V
PIN 6: 5.2V
There being the same voltage on both op-amp inputs usually means that it's in control of the CV loop.
Because the voltage feedback divider has a ratio of 3:1, the PSU's output should be close to 15V.
Some things are not right. Because the reference voltage is supposed to be 11.2V, the wiper of the CV Pot and pin 3 of U2 should also be 11.2V with the Pot fully clockwise.
  • Country: tn
« Reply #8 on: November 04, 2019, 07:12:04 am »
PIN 2,3: 5.07V
PIN 4: -5.6 V
PIN 7: 30.1V
PIN 6: 5.2V
Yeah i know thats something goes wrong in that area and i'm pretty sure that's the TL081 is  not behaving well , i will replace it with new one and recheck the results , hoping that will fix this issue because i'm really fed up , its almost one year now since i bought this piece of scrap  |O :palm: >:(
« Last Edit: November 04, 2019, 07:15:35 am by Ahmed Khouaja »
Offline xavier60
« Reply #9 on: November 04, 2019, 07:16:38 am »
If you put a load on the output, does the voltage hold up or does it drop?
  • Country: tn
« Reply #10 on: November 04, 2019, 07:31:16 am »
Well i didn't try it but , i shorted the circuit wich gives me 3.3V approximetly as voltage and 4.25 as Ampere ( 2V across the R7 {Rshunt})...
Offline xavier60
« Reply #11 on: November 04, 2019, 07:40:11 am »
It would have been best with a normal load that doesn't cause current limiting so that the tests are on the CV loop only.
If a small load causes no drop of output voltage, it will mean that the op-amp is functioning properly and that one of the problems is with the feedback divider. The feedback divider is supposed to divide the output voltage by 3.
Maybe a wrong value resistor.
« Last Edit: November 04, 2019, 07:47:42 am by xavier60 »
  • Country: tn
« Reply #12 on: November 04, 2019, 07:50:33 am »
Well , for the 11.2Volts in the 2 amplifiers are coming from the U1 wich in my case is right, means that the first amplifier function well , so that 11.2 Volts needs to appears in the R15 of the output circuit wich in my case is the only error, so the question is , what makes this 11.2Volts divide by 2 in the R15 wich is the bad result, i checked all the resistors in that area and theye are good that what keeps me out of my mind  :palm:
Offline xavier60
« Reply #13 on: November 04, 2019, 07:58:32 am »
The best way to diagnose a fault is by first understanding how the circuit is supposed to work.
Starting at the CV Pot, take voltage readings to find where the voltage drops down from 11.2V on its way to pin 3 on U2.
What is the voltage on both ends or R8?. then pin 3 again
« Last Edit: November 04, 2019, 08:01:22 am by xavier60 »
  • Country: tn
« Reply #14 on: November 04, 2019, 08:12:47 am »
Well at R8 the voltage is equivalent to the pin6 of the op-amp wich is 5.2V
Well i have clearly image for the schematic diagram , can you please tell wich resistor i need to check and focus on it ?
866308-0
Offline xavier60
« Reply #15 on: November 04, 2019, 08:22:13 am »
Take exact voltage readings on the
left side of R8,
right side of R8,
top of R9,
and pin 6 of U3.
Offline nali
« Reply #16 on: November 04, 2019, 09:02:53 am »
left side of R8,
right side of R8,
top of R9,
and pin 6 of U3.
...and Cathode of D9
  • Country: tn
« Reply #17 on: November 04, 2019, 03:48:20 pm »
Okey, i'll check them when i replace the U2 and the 2 transistors 2SA9015 and the 2SA9014....
  • Country: tn
« Reply #18 on: November 05, 2019, 02:28:33 pm »
Finally guys, i just made it , i fixed it.
The problem was with the U2 :TL081
The output of this IC was giving only 6V as maximum output...
Thank you guys for your replys , it really helps me ...
