I believe that it would be proper way to put the whole project description but i hope it might be enough for someone with experience.
So, very simple thing.
I power up ESP8266, it boots, everything works fine.
I hook one of those cheap songle relay module boards (i tried other relays too, same thing) and controlling the relay works perfectly. No issues there.
However, if i leave it like that and restart EPS (power down/up), the esp never boots up, and there is silent buzzing from the relay.
Probably this might be all you need:
Between the ESP IO pin and relay board i have 1K resistor, 2n3904 NPN transistor and it switches 5V relay powered from external 5V.
Any clues?
