I have a yamaha DX7 Synth from the 80s.
I have heard horror stories about caps in the power supply blowing up, and I think it's time I do some preventative maintenance on it. The stories I've heard describe the power switch not working anymore, and being unable to turn off the synth while it's billowing smoke, forcing you to go unplug it from the wall.
I have attached a snippet from the schematic. I believe based on this description, that cap C1 must be failing shorted, thereby bridging the power switch. Does this make sense?
So - I'm from what I'm reading that I should be looking for a "Safety" cap so that the replacement would fail open, not shorted, but I'm not sure how to identify that.
Secondary to that question is a more basic question - My understanding of caps is that they let AC flow, but block DC, so I'm wondering how this cap isn't seen as a dead short across the power switch during normal operation in the first place. I'm sure it's my bad/limited understanding of caps, and that it comes down to the value of the cap not being able to pass 60hz, but I'm wondering if someone could tell me just for my own comfort zone, what the frequency of AC this cap would pass vs. block?
In the schematic, I have included the European version because that's what shows the entirety of the DC side of the supply. The top of the US one is shown below, and is identical for the parts in question, and just has a different transformer for the different input voltage..
Thanks in advance!!!
-Steve in Maryland
