Author Topic: Component selection help - 17IPS20 repair  (Read 1588 times)
Offline DenialMyOldFriendTopic starter
« on: May 27, 2020, 04:08:54 pm »
Hi, first post here, and I'm really rusty - haven't got my soldering iron out for years, so I'd like to check a few things before I bugger something up worse than it already is.
I'm trying to fix a 17IPS20 power supply in a telly I was given (schematic attached). The rectifier seems cooked and I can't get hold of RL207s at a decent price, so should it be OK to replace them with IN5408s?
IN5408 - http://www.farnell.com/datasheets/314353.pdf
RL207 - http://www.farnell.com/datasheets/1684861.pdf
Also one of the mosfets shows a short source-drain unpowered. I seem to remember that means it's scragged - or am I confused there?
Many thanks if you can help.
« Last Edit: May 27, 2020, 04:13:21 pm by DenialMyOldFriend »
Offline fzabkar
Re: Component selection help - 17IPS20 repair
« Reply #1 on: May 27, 2020, 08:22:56 pm »
1N5408 is OK.
Testing MOSFETs:
http://www.4qdtec.com/mostest.html
The following users thanked this post: kastell123, DenialMyOldFriend
« Reply #2 on: May 28, 2020, 09:44:37 am »
Spot on, thanks mate.
