Finally, I had the time to take it apart again and checked the fuse the second time. Unfortunately, it was okay
I assumed that if one switch was failing, there might be more mechanical issues along the current path from the front to the rear input relay assembly.
The I+ rings out all the way to the current board, I- does not when I/dc selected.
Therefore, I took the relay board out and did some fault finding.
In my understanding (might be wrong), those relays should operate from +15V dc so thought - yeah let's test it on the bench. Hooked it up to 15V dc, nothing, a slight bodge at most. Increased the voltage to 24Vdc and it clicked. But it still does not work on 15Vdc..
Is there anything special about these relays? I can't seem to find anything when I googled the part number.
Cheers,
Laz
