I took the measurements. The device has two modes: standard and quiet. In normal operating mode, the current of the elements in the string is 4.2 amperes at 17.6 volts. That is in silent mode 3A at a voltage of 13.77 volts. Efficiency testing was performed in quiet mode.
I have currently started the device in its disassembled state, in silent mode. After ten minutes of operation, the temperature of the hot radiator reached seventy-eight degrees, and that of the cold one, thirty-five degrees. The fan blew air only over the hot radiator, so the cold radiator became covered with frost. t hot 78, t cold 35, t room 73.
The hot radiator is large and has a large surface area, with a fan mounted on it; however, the radiator temperature dropped by only a few degrees. The fan itself is very noisy.
There is an idea to run the system at higher power but reduce the fan speed. I want to reduce the speed of this fan by connecting another, lower-capacity fan in series with it—a fan that will blow air over the cold side.
