Author Topic: Difficulty repairing UC3842 power supply...  (Read 12526 times)
Offline dave_kTopic starter
« on: August 14, 2017, 12:45:21 pm »
Was recently asked to look at a small switchmode power supply to repair.
Initial diagnosis was blown mains fuse (2A), shorted FET and failed TL3842 controller. Dead semiconductors were replaced, along with 2 small electros on the primary side.
Applied power (via isolation transformer and 100W series bulb). 100W bulb glowed briefly confirming main filter cap charged up, however no output voltage was measured.
After some probing and measuring it appears the 3842 is not starting up, pin 7 not reaching the 17.5v needed to begin operation (measured a peak of ~14v).
Feeding 18v from an external supply into pin 7 causes the 3842 starts up and the supply runs. During operation, pin 7 has between 10.5-11.5 volts present (coming from the AUX winding supply).
The start-up supply for the 3842 is a little unusual in this design. Instead of a resistor from the main DC rail, a small capacitor is connected to one leg of the incoming mains (used as a voltage dropper) then rectified by a pair of diodes. The value of the cap is 0.22uF which has a reactance of about 15k ohms at 50Hz.
All other components on the primary side have been individually checked and tested OK.
My question is what would be stopping this supply from starting up normally?  :-/O
Reverse-engineered schematic:
(secondary side has been omitted, it's a bog standard TL431 driving the opto).
« Last Edit: August 15, 2017, 01:35:54 am by dave_k »
Offline Armadillo
Re: Difficulty repairing UC3842 power supply...
« Reply #1 on: August 14, 2017, 12:52:54 pm »
Have you replaced the 0.22uf?
« Reply #2 on: August 14, 2017, 12:55:13 pm »
Offline Armadillo
« Reply #3 on: August 14, 2017, 01:03:28 pm »
Would you be able to probe the aux supply?
« Reply #4 on: August 14, 2017, 01:09:15 pm »
At one stage D1 and D2 were removed. Starting the 3842 using a pulse of 18v external supply, pin 7 measured 10.5v after external supply was disconnected.
It appears the AUX winding is able to power the 3842 without difficulty (once it starts)..
Offline Armadillo
« Reply #5 on: August 14, 2017, 01:11:07 pm »
Maybe the secondary needs to be loaded?
« Reply #6 on: August 14, 2017, 01:18:05 pm »
I thought this as well. Loading the output with 1A doesn't change the result .. still refused to start on it's own.
Once started, it can happily run and supply up to 3A. Voltage regulation is quite good, output dipping by only a fraction of a volt at this load.
Fundamentally the supply works, it just doesn't start. This is where I am stuck, there is something I am overlooking.  :-//
Offline kripton2035
« Reply #7 on: August 14, 2017, 01:26:08 pm »
I would replace C2
« Reply #8 on: August 14, 2017, 01:27:56 pm »
Already did that .. C2 and C4 both replaced.
Offline carl_lab
« Reply #9 on: August 14, 2017, 01:46:00 pm »
Are you sure your wiring of the optocoupler is correct (emitter is open)?
OK, you have corrected now...
« Last Edit: August 16, 2017, 08:41:32 pm by carl_lab »
Offline Armadillo
« Reply #10 on: August 14, 2017, 01:48:28 pm »
I am sure you have dig through the power supply and replaced all that can be replaced, except the aux windings.
The aux could be a bit nicked.
Maybe the short cut, would be to replaced the 0.22uF to something a bit higher, say try 0.47uf.... 0.68uf.... if you have the appropriate capacitors.
Just a suggestion.
Offline CJay
« Reply #11 on: August 14, 2017, 02:01:19 pm »
I reckon D1 should be a Zener and C2 should be a higher value, they're usually around 22uF-100uF, has someone else been in there first?
Offline xavier60
« Reply #12 on: August 14, 2017, 02:07:43 pm »
I notice there is no Gate to Source bleed resistor shown. With some versions of the UC382, the output pin stays in a Hi Z state while the IC is in UVLO state. If there is no Gate bleed resistor, the Gate eventually charges up, blowing the MOSFET again.
http://www.st.com/content/ccc/resource/technical/document/application_note/3b/42/e6/d9/78/47/4d/df/CD00003930.pdf/files/CD00003930.pdf/jcr:content/translations/en.CD00003930.pdf
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline xavier60
« Reply #13 on: August 14, 2017, 02:28:06 pm »
Leaky diodes often don't test bad with a DMM. I notice that when small glass diodes have corroded leads, they tend to be leaky.
The value of C2 seems unusually small.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #14 on: August 14, 2017, 04:01:25 pm »
Dang, full schematic capture?  Very nice! :-+
The 3842 is supposed to be off (<1mA supply consumption) until it kicks on.  If it can be powered by the startup circuit, it should more than start up normally.  That's your mystery to solve: what is sucking down all the current, or keeping the startup from delivering enough current?
I wonder if the 3842 has been damaged in such a way that it's very leaky, but still otherwise functional?
Seven Transistor Labs, LLC
Offline Kevin.D
« Reply #15 on: August 14, 2017, 06:43:16 pm »
Are you sure your schematic of the startup circuit is correct , ? The way it is shown it  only supplies a single startup current pulse on the first mains  cycle as C3 is initially charged  (so c3/c2 form a capacative voltage divider with C2 charging up-to ~ Vmains(peak)* C3/C3+C2).
Once C3 has charged it has no means to discharge hence no further pulses are available on following mains cycles.
If this is what is actually intended then the ratio of c3/c2 determines Vstart (and after a power down you would have to wait for C3 to discharge (shown here only possible via D2 leakage) before another startup pulse was possible).
The only other thing to check is if it's being dragged down like others suggested.
regards
« Last Edit: August 14, 2017, 07:14:58 pm by Kevin.D »
Online T3sl4co1l
« Reply #16 on: August 14, 2017, 11:38:58 pm »
Oh, yeah, that one diode is on the wrong side.  I hope?  :phew:
« Reply #17 on: August 15, 2017, 12:19:24 am »
Altium is good for something, right?  :-DD
Yes, and this is where I am getting stuck.
The schematic I posted probably doesn't tell the full story, the part numbers are of the original unit.
The SSP6N60A MOSFET (made by Samsung) was replaced with a IRFBC40PBF (Vishay). The original PWM IC was a Texas Instruments TL3842P, it has been replaced by a Texas Instruments UC3842N
One avenue of thought was the replacement MOSFET was unsuitable (thinking Qg was too high) and the 3842 was having difficulty initially turning it on. Comparing data sheets shows original MOSFET Qg is 77nC max, replacement is 60nC.
Original 3842 was replaced, plus I have tried 2 other 3842's from junked equipment - same result with each chip.
« Reply #18 on: August 15, 2017, 12:20:58 am »
Oops, yes - D1 is indeed connected to the anode of D2 (drawing error).
Original post has been modified with the correct schematic.
« Last Edit: August 15, 2017, 01:12:50 am by dave_k »
« Reply #19 on: August 15, 2017, 03:18:20 am »
UPDATE: problem found and fixed. Anybody want to have a guess at the solution?
Offline carl_lab
« Reply #20 on: August 15, 2017, 10:06:34 am »
Dead electrolytic cap?
Open soldering joint?
Some loose connection?  ;)
Offline oldway
« Reply #21 on: August 15, 2017, 02:19:41 pm »
What's the voltage on C2 ?
Offline xavier60
« Reply #22 on: August 16, 2017, 08:35:25 am »
Anything to do with the isolation transformer?
Offline mzzj
« Reply #23 on: August 16, 2017, 10:02:51 am »
Leaky diode
« Reply #24 on: August 16, 2017, 11:58:24 am »
Turns xavier and CJay were on the right path. After reading through a few data sheets and application circuits for the 3842 it was became obvious that C2 was too small. Increasing the value to 100uF allows the supply to reliably start.
Now another problem needs attention. With the supply running (even with minimal load) the MOSFET heatsink becomes quite warm after a few minutes.
Thoughts are either: 1) low gate drive and MOSFET not turning fully on, or 2) problem with snubber circuit.
Will try and capture some scope traces tomorrow..
« Last Edit: August 16, 2017, 12:00:41 pm by dave_k »
