Author Topic: Digital clock unconnected resistor  (Read 2328 times)
Offline aljowenTopic starter
« on: May 07, 2016, 05:37:42 pm »
On my digital clock I noticed that the Temperature readout on it has been a couple deg c out for quite some time so I decided to open it up to see if it had any trimmer pots inside with the hopes of adjusting it, while I sadly didn't find any trimmer pots I did find this:
I have never noticed an issue with the clocks functionality, That resistor capacitor connects +3v directly to the switch, and the switch seems to works fine as is.
So my question is, Do you guys reckon it was ever supposed to be connected on this configuration of the board?
Some extra images just in case people are interested in them (its either oct 2004 or 2002, its stamped inside but the last digit is messed up) :
« Last Edit: May 07, 2016, 05:58:36 pm by aljowen »
Offline Neilm
Re: Digital clock unconnected resistor
« Reply #1 on: May 07, 2016, 05:46:44 pm »
Are you sure that is a resistor? It looks more like a ceramic capacitor to me.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
The following users thanked this post: aljowen
« Reply #2 on: May 07, 2016, 05:51:12 pm »
Yes, you are correct. Just tested it.
Never done surface mount before and thought that they were resistors, my bad.
« Last Edit: May 07, 2016, 05:55:37 pm by aljowen »
Offline Raj
  • Country: in
  • Self taught, experimenter, noob(ish)
« Reply #3 on: May 21, 2016, 03:45:17 pm »
looks like a button de bounce filter cap to me
Offline Yansi
« Reply #4 on: May 21, 2016, 03:46:49 pm »
Just solder the little bastard where it should be. The other pad is next to it. (Seems manufacturing defect and poor quality control in the manuf. process)
Offline Raj
  • Country: in
« Reply #5 on: May 21, 2016, 03:47:09 pm »
I always say to myself... don't fix it unless it's broken
