Hi.
A friend of mine sent me these images of a 24V PSU for floorheating in his caravan.
I can recognize it as a switchmode PSU. But the plate on the unit does not make sense.. It it stating that the output is 24Vrms AC
and also that it is dual voltage in - there is no input terminals for 24V AC.
The lead is the mains input. P3 is the output.
The problem is that it is measuring with no load 34.5V DC and 84V AC on the output, with load - it is measuring 35,5V DC and 77,5V AC. It is making a high pitch humming noice at load.
The load is measured to 400 ohms and it is a floorheating mat. 24V into 400ohms would give a current of 16.6 A, so this unit is clearly not up to the full task but is factory installed.
A new unit from the caravanshop is around 400 USD (4000 Norwegian Kroner).
I do not have the unit at hand at the moment, I might get it later today.
Do any members have any tips in what I should check.
Thanks in advance.
