Author Topic: Elektro Automatik Power Supply PS3032-20B  (Read 3660 times)
Offline powertomiTopic starter
  • Country: hu
« on: August 19, 2018, 09:20:01 am »
Hi everybody!
Please help me!
I need schematic or service manual this PSU.
Not powered on... :(
Thaks for help!
Offline coromonadalix
Re: Elektro Automatik Power Supply PS3032-20B
« Reply #1 on: August 19, 2018, 12:55:21 pm »
could you show us inside photos, maybe its an rebranded model
Online mk_
  • Country: at
« Reply #2 on: August 19, 2018, 01:15:02 pm »
Ask EA  directly.
Usualy their technical support is very helpful - even for parts no longer in production...
Online mahi
« Reply #3 on: August 19, 2018, 03:53:54 pm »
I agree with mk_. When my old EA Elektro-Automatik PS2316-050 lost a channel (long out of warranty) I mailed them for service documentation. While they did not have a real service manual available they promptly sent me the complete schematics which were very helpful in repairing the fault. I'm not sure they'll do that for devices that are still being manufactured/sold but it's worth a try.
PS: You did check the fuse on the back, right?
« Last Edit: August 20, 2018, 01:45:41 pm by mahi »
  • Country: hu
« Reply #4 on: August 20, 2018, 09:15:03 am »
Thanks a lot!
I try to ask for help from their technical support...
  • Country: hu
« Reply #5 on: August 30, 2018, 08:15:06 pm »
This is the aux power supply.
When power on, the input power inceases 70 between 100 VAC first the aux power supply started, the Volt/Amper display lighting up.
If the input voltage continue increases to 150 VAC the main supply wake up.
Between the main output ( Red-Black ) jack I measured cca. 20 Ohm.
Maybe this is a short circuit?
Now the aux supply can't start- try per second...
The support it has helped me so far...( sen to me the aux ps picture)
It stopped a few days ago.
I waiting...
« Reply #6 on: August 31, 2018, 08:31:43 am »
this section gives +15v, -12v and an unknown voltage at X17 pins , maybe guess 24vdc at least ???  and an control line going to the v35 diode.
I see there is mention of an powerfail sense line too ???
If you say  you have an 20 ohms impedance at the psu main output, it is definitely an problem,  maybe you have some diode protection shorted out ???
Takes many photos of your boards and show us ... we could find something ?
  • Country: hu
« Reply #7 on: August 31, 2018, 08:27:35 pm »
Thank You for answer!
Next week I send photos,
In weekend I worked as sound technician  ( lot music-not enough sleep )...
  • Country: hu
« Reply #8 on: September 23, 2018, 07:20:03 pm »
Here the pictures..
Offline cvanc
« Reply #9 on: September 24, 2018, 01:50:28 pm »
Looks like a nice supply, good luck with your fix.
This is a little bit of a worry, could it be evidence of overheating/burning?  Might want to remove & evaluate that inductor...
