There is another repair of this counter model on the forum, find it here:
https://www.eevblog.com/forum/repair/counter-repair-enertec-schlumberger-2618/ . All the schematics I have about this I got from this thread.
So I got a new counter, bought broken from ebay. The counter has three inputs, called A, B and C (Imagine that).
From looking at pictures it seemed like A and B are pretty much identical to each other. C is a prescaler for A. It extends the upper range to 1.2 GHz. This was the main reason for me buying this device, as I don't have anything that can measure that high (but I do have a source that can generate). The seller advertised it as A & C not working, B functional.
When I got the device, it seemed like the seller was wrong. A and B are broken, C seems to work (see picture below). I suspect that they just didn't look at the front panel when testing and went "The second connector must be B".
Channel B does seem to be able to count intervals, which is something. A doesn't do anything usefull, sometimes when I move a switch it will read a short value (unrelated to whatever I'm trying to put in the input).
I'm not sure how much of this is me just not understanding what the buttons do and not the unit malfunctioning, although looking at the schematics has helped me understand some of it. As frequency counting doesn't do anything on A or B, I suspect it is going to be something that they must share, but they don't share with anything to do with input C - I'm going to look at some voltage rails but I would suspect if they are the fault, nothing would work at all.
I also quickly checked the oscilator and it seems to be quite accurate. I'm still looking at getting a GPSDO or GPSRO in the near future, though I have some other stuff I need to sort out before I'm spending money on that. I'll keep updating this as I try stuff out, now first I just need to figure out what it is I am going to start probing.
