Author Topic: "Estrada 101" 4 channel soviet amplifier, 1st channel problems.  (Read 1996 times)
Offline Deactivated-1Topic starter
I'm having problems with my Estrada 101 amplifier, when I turn it on, sometimes the 1st channel protection light doesn't turn off, but after around 3 minutes it turns off. at first, I thought it was just a sticking relay, but then after around half an hour, I hear a pop and smell something burnt, the amplifier 2nd channel (which I was using at the time) was still working, none of the protection lights came on.
so I turned it off, and the first thing I did was pull the 1st channel block/preamp out and look for anything there, and I saw the R39 resistor burnt, and nothing else.
when looking at the schematic I would think that there is no way for the R39 resistor to be blown with the correctly sized fuse F2, the fuse would've just blown.
maybe if pin 5 on the preamp block, if that gets shorted to ground maybe then, but I examined the rest of the amplifier and saw no place that it could be shorting.
Maybe I should take it more apart and look closer at the first channel circuitry
the protection light problem followed the amplifier 1st channel, not the 1st channel preamp board, so the problem must be in the amplifier
also, all the fuses are original ones and the proper value.
I've attached the schematics of the amp
Offline Chris56000
Re: "Estrada 101" 4 channel soviet amplifier, 1st channel problems.
« Reply #1 on: March 01, 2021, 06:48:46 pm »
Hi!
Is there any chance you could scan all the pages of the book you got that from please?
There's a lot of useful additional information in Soviet manuals, including coil and transformer winding details, full voltage tables and layout diagrams, etc!
This would assist me in rendering an English diagram for you!
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Offline serg-el
  • Country: ru
« Last Edit: March 01, 2021, 11:11:40 pm by serg-el »
Offline serg-el
  • Country: ru
« Reply #3 on: March 02, 2021, 02:07:33 pm »
So does the relay turn on / off? Is the protection lamp still on?
R9 in the amplifier sets the output zero balance. R26 sets the quiescent current. It is imperative to adjust the balance, otherwise the protection will work.
Check / replace C3 and C5 in the protection circuit.
C3 power-on delay. C5 delay during protection operation.
And without replacing electrolytic capacitors, repairs are pointless. They are 100% defective.
« Last Edit: March 02, 2021, 02:09:42 pm by serg-el »
