Author Topic: Fluke 289 super capacitor  (Read 9723 times)
Offline ELCouzTopic starter
  • Country: aq
« on: September 25, 2018, 09:50:34 pm »
I am out of warranty for the Fluke 289 and I need to replace the super cap which of course is leaking.
Any part # or equivalent specs for a better than the OEM Panasonic one?
Thank you very much!
Laurent
Offline dacman
Re: Fluke 289 super capacitor
« Reply #1 on: September 25, 2018, 10:35:59 pm »
There are lots of threads on that.  Just search for 289 Super Capacitor.
« Last Edit: September 25, 2018, 10:49:52 pm by dacman »
Online coromonadalix
« Reply #2 on: September 25, 2018, 10:52:47 pm »
Rebuilt my Flukes 189 with theses  :
https://www.digikey.com/product-detail/en/elna-america/DX-5R5H104U/604-1022-ND/970183     100mf or 0.1 farad
https://www.digikey.com/product-detail/en/elna-america/DX-5R5H334U/604-1024-ND/970185     330mf or 0.33 farad
I used the 5.5volts super cap, with a slight pins bending they fit perfectly ....  be careful of the polarity, there an small "-"   (minus sign) on the top  and check on the pcb  before removing the ''old'' part, dont over heat the pcb traces, and do an proper board cleaning after.
The following users thanked this post: Trader
Offline joeqsmith
« Reply #3 on: September 25, 2018, 11:01:14 pm »
I'm using a similar part.
https://youtu.be/8t8nkCbYJVc?t=17
Offline Fabry_85
« Reply #4 on: January 30, 2019, 11:20:39 am »
HELLO boys!
I need your help. :'( :'( :'(
I have the tester 289 that as I turn on gives me an "incorrectly connected cables."
Could it be the super capacitor?
it is damaged. the fluke is 289 and of the year 2008.
I found on ebay a PANASONIC GOLDCAP KONDENSATOR Capacitor 0,22F 3,6V 10x5MM[/img].
You can help me?
Thank you.
« Reply #5 on: January 30, 2019, 06:16:08 pm »
If i recall you have optocouplers for the leads detection
Offline ElecSeb
« Reply #6 on: January 30, 2019, 06:49:09 pm »
Correct  :-+
Offline mr.fabe
Offline Fabry_85
« Reply #8 on: January 30, 2019, 09:20:25 pm »
Can you please tell me exactly wich optocoupler is damaged? I do not have a schematic.
At first it happened sometimes in cold and wet environments. Now it always has this bad behavior.
Can I find the same octocoupler ? Do I need to replace it with a compatible one?
Thank you
Offline Fabry_85
« Reply #9 on: January 30, 2019, 09:26:25 pm »
You're right. Where can I find it in Europe or Italy?
Anything compatible?
Online 2N3055
  • Country: hr
Dr. Richard W. Hamming
Offline Fabry_85
« Reply #11 on: February 03, 2019, 01:37:20 pm »
the Ds2 must be welded like this?
Inviato dal mio FRD-L09 utilizzando Tapatalk
Offline ElecSeb
« Reply #12 on: February 03, 2019, 02:14:35 pm »
That is upside down!!
Offline Fabry_85
« Reply #13 on: February 03, 2019, 05:52:54 pm »
Ok! thanks.
Offline ElecSeb
« Reply #14 on: February 04, 2019, 07:19:11 am »
The PCB you show looks like it has been soldered before... No by you I suppose?
Are you sure the meter is still working?
I am sorry for my bluntness, but based on your shown experience you do not seem to have that much experience in electronics...
Are you sure you are capable to make this repair and would it not be wiser to put this one with a correct description on ebay and buy yourself a working new one (calibrated and within spec?)
Offline marrob50hz
  • Country: hu
« Reply #15 on: July 18, 2024, 11:15:32 am »
Hello,
I found a perfect replacement for C145 supercap
Mfr. No:ELNA RSCSK2043R3D01004T
https://eu.mouser.com/ProductDetail/Elna/RSCSK2043R3D01004T?qs=4ASt3YYao0W6joWWDTvrLg%3D%3D
The following users thanked this post: Swake, TheDefpom
