Desolder all 3 MOVs. They are all bad.
With the MOVs desoldered, remeasure the green PTC. It should be around 1.1K ohm. If not, desolder the PTC as well.
For testing purposes only, solder in a normal 1K ohm resistor in place of the PTC. The 87V will work without the MOVs installed. It just won't give you the high energy protection.
Retest the 87V with low AC/DC voltage measurements and small resistors. If all works well, then you can buy new MOVs and PTC.
Fusible resistor is good.
