Initially the 1/3, 2/4 pairs behaved differently - former were up top, latter down bottom. Now all are off the bottom.
The hybrid voltages -7VA, 5VA and 18VJ are all there, slightly low but within 10%.
The hybrid output ANINA at pin 3 for channels 1&3 is at -5.67V, not -0.5v as it should be. Biasing this up to -0.5V with a resistor brings a trace onto the screen.
So why is the ANINA signal over 5V below what it should be? Giving the hybrid the benefit of the doubt for a bit, I checked over the MASPU-A. Some of the voltages are not what they should be.
-12VA1 at pin 19 was -5.8V instead of -12V, and was caused by a 1R resistor gone high. I replaced it, and it’s correct now.
Voltages at V8019 and V8021, a DC feedback loop, were not 1V and -5.4V but 6V and 2V. These seem under control of the MASPU, so I moved on. 10V ref and the components checked out OK, anyway.
The other problem was pin 68 BOOT, which was at 2.46V, not -0.5V, but apparently this is a feedback from the hybrid. It’s looking a bit like the hybrid, isn’t it?
