Author Topic: Futuba VFD replacement?  (Read 3226 times)
Offline PaulAmTopic starter
« on: February 02, 2017, 11:06:37 pm »
I'm repairing an old HP DesignJet plotter and I have an unreadably dim VFD display.  I had a used replacement, which is at least readable, but it's still not as bright as I'd like.
This is a Futuba US202SD01A display which is a 2x20 VFD with the associated support circuitry and uses a 5 pin serial interface connector.  Apparently, somebody has reverse engineered the protocol and there's a library available to drive the display from an Arduino, but I'm coming up blank on a display replacement.
Anyone have a NOS unit gathering dust?  Maybe just the VFD?  Doesn't look like fun to remove and replace it, but it's doable.
Offline BradC
Re: Futuba VFD replacement?
« Reply #1 on: February 02, 2017, 11:23:46 pm »
I replaced mine with a 2x20 LCD but there are "issues" with special characters and it most certainly won't work with anything other than English. That Futaba display has a plethora of special characters and you only have space for 8 in the LCD. I toyed with a dynamic loader to load them as needed but it was more hassle than it was worth.
I reverse engineered the protocol and wrote a converter for the Parallax Propeller. That was years ago now, I'll have a look and see if I can find the code. It's a funky protocol.mfrom memory it starts out 8 bit and then switches to a 10 bit stream after boot up.
I had no luck sourcing credible vfd replacements.
Offline james_s
« Reply #2 on: February 03, 2017, 12:24:14 am »
2x20 VFDs are fairly standard, you may be able to transfer the glass from a similar display to the board on yours but beware some of the modern ones are "chip on glass" with an internal driver.
You can also rejuvenate VFDs, have a look online. Essentially you boost the filament voltage to burn off contaminates and expose a new layer of emissive oxides, similar to rejuvenating tired CRTs. VFDs are essentially inside-out flood gun CRTs.
« Reply #3 on: February 03, 2017, 02:18:49 am »
Well some more looking and I found some NOS Futuba NA202SD08FA displays which appear to use the same display and the same driver chips.  I have a couple on order and we'll see if they work out.
This display has all the leads on one side.
An alternative would be to get a current display and put in a protocol converter, but that's more work than I really want to do.  Transferring the display will be bad enough.
Offline james_s
« Reply #4 on: February 03, 2017, 04:16:14 am »
Have you tried rejuvenating it? I found the page I was thinking about, turns out it's right here on eevblog.
https://www.eevblog.com/forum/chat/vacuum-fluorescent-display-rejuvenation/
« Reply #5 on: February 03, 2017, 01:35:50 pm »
I'll give it a shot and see what happens; it might be good enough.
