Author Topic: Help in identifying strange proximity switch component  (Read 2352 times)
Offline MesstechnikerTopic starter
« on: November 20, 2018, 06:40:37 pm »
I have here a busted proximity switch consisting of two identical components
(one operative the one other busted :palm:). More details in the enclosed pic.
Can anyone tell me what kind of component this is? :-//
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
Offline ataradov
    • Personal site
Re: Help in identifying strange proximity switch component
« Reply #1 on: November 20, 2018, 07:12:48 pm »
What is the physical appearance of the switch? Any pictures? Markings on the device?
Alex
« Reply #2 on: November 20, 2018, 08:18:55 pm »
Thanks for your assistance.
No markings on the device.
It's round. 11 mm in diameter and 13.5 mm long. Top surface is black.
Has two wires - black and blue - coming from the bottom.
It has been press-fitted into a white plastic surround having a diameter of 19 mm.
There are two of these devices wired in parallel.
Sorry no pics at the moment because I don't have it in my lab.
Was measured in the field. :palm:
Offline tautech
« Reply #3 on: November 20, 2018, 09:31:23 pm »
A 2 wire hall effect sensor ?
Avid Rabid Hobbyist
Online coromonadalix
« Reply #4 on: November 20, 2018, 09:32:19 pm »
yep  my tought too
Offline JFJ
« Reply #5 on: November 21, 2018, 12:56:33 am »
Unless a current was flowing through the piece of aluminium, there wouldn't be a magnetic field for a Hall effect sensor to detect. The device is more likely to be a 2 wire inductive sensor - NC (normally closed) type, as the presence of the aluminium increased the voltage drop across the sensor.
« Reply #6 on: November 21, 2018, 06:30:52 am »
Thanks for considering this question.
Here some more information:
The "Transistor Tester" measures with nothing in the vicinity, the isolated (i.e. not in-circuit) component as a diode with
Uf= 2.9 V
9.2 .... 8.2 nF @0...5 V
Ir = 21 nA (1.4 uA for the defective sensor)
And with the Al piece present it measures 9343 pF (and nothing for the defective sensor).
I'll be getting back to the sensor assy. in a day or two to see how the sensor responds to other materials (steel, magnet, finger, wood, brass and plastic).
<Solved> Re: Help in identifying strange proximity switch component
« Reply #7 on: November 22, 2018, 03:54:39 pm »
Sorry folks. Went down the wrong rabbit hole :-DD
Since the sensor responds to aluminium, steel and copper and not to a finger, wood or plastic it is not of the capacitive type.
Moreover, measuring with a coil connected to a scope, a 1.23 MHz sine at the sensor surface indicates that this is an inductive (eddy current) proximity sensor. Possibly even a hall effect sensor.
With the oscillation present it draws a current of 2.6 mA. I.e the voltage output is low at 2.1 V. With conductive material present the oscillation amplitude reduces more and more until it ceases completely. Current draw is then 0.6 mA and the output voltage is high at around 3.4 V. :phew:
Next step: sifting though data sheets to find an electrically and mechanically matching two-wire inductive sensor. This is going to be the non-fun bit. :palm:
« Last Edit: November 22, 2018, 03:58:58 pm by Messtechniker »
« Reply #8 on: November 22, 2018, 07:48:02 pm »
Look up intrinsically safe inductive sensors, commonly known under the generic NAMUR sensor. there will be one that fits there.
http://www.tektron.ie/namur1.htm
The following users thanked this post: Messtechniker
« Reply #9 on: November 23, 2018, 06:12:58 am »
Well, that pritty well nails it. 8)
