Author Topic: Help me identify this transistor  (Read 2670 times)
Offline drummerdimitriTopic starter
  • Country: lb
« on: March 20, 2015, 07:27:37 pm »
Hello,
A transistor started smoking due to a short on a car battery boost device and I would like to know what the specs are and where to buy a replacement from.
I've attached a picture of the component and there is sign of physical damage due to overheating.
Cheers!
Offline Cliff Matthews
    • General Repair and Support
Re: Help me identify this transistor
« Reply #1 on: March 20, 2015, 07:35:06 pm »
Just my 2-cents, but with the middle pin cut like that, it was probably a diode... I've got several like that.
  • Country: lb
« Reply #2 on: March 20, 2015, 07:37:56 pm »
I'm am electronics noob so you might be right. There are three of them soldered next to each other on a plate of copper. Maybe some input protection diodes?
It reads T460 on the top and BV0T1A below that but I have no clue what it is and if the other two are defective or not.
Offline Andy Watson
« Reply #3 on: March 20, 2015, 07:59:23 pm »
Try Alpha & Omega Semiconductor  AOT 460.   N-Channel Mosfet.
Online PA0PBZ
« Reply #4 on: March 20, 2015, 08:36:15 pm »
Seems right, but why would you cut off the drain?
Because it is connected to the metal of course...
« Last Edit: March 20, 2015, 08:37:51 pm by PA0PBZ »
