One of my nephews has a hoverboard (the same kind that is known to catch on fire, but I think this particular model does not have that issue, and it's also UL approved, so there's that). At random it decided it would not turn off. Had to open it and unplug battery, but it just goes back to that mode when you plug it back in. So clearly something is wrong in the control board somewhere. It does recognize the power button as it beeps when you press it, so I know it's not the button or it's circuitry but something beyond that.
Upon some googling I found some things saying it's a common issue, and that I may need to replace two transistors and some capacitors but some rather broad info and nothing specific. I have a general idea which ones, but just figured I'd post here in case someone might actually be familiar with repairing these. If I do replace the transistors also wondering if I should go with something with a higher rating instead of a direct replacement? I don't want to just be slapping in the same parts if it's actually a known issue, as they'll probably just fail again right? The transistors are in TO-220 packages so they are decently heavy duty but they arn't for the motors as there is a set of mosfets on a heat sink that serve that purpose.
I've thought of just adding a kill switch for the whole battery, as the hoverboard still works when it's stuck in that mode where it won't turn off, but then there is not really anywhere to physically place one as it would stick out somewhat. The built in switches are recessed into the plastic but that would be kinda hard to custom make. Finding a switch that can handle 40ish volts DC at a rather high amperage may be hard too. The battery cable is what appears to be 10gauge so probably looking at close to 40 amps max so I'd probably want to rate the switch for that.
I'm leaning towards the transistors as I read but just wondering if anyone has worked on these before and has more details.
Found this video, but can't hear the guy talk but he does point towards the parts, so suppose it's something to start with.
